geetha.diwakar
fail to run the code xlinx sdk
hi ,
     I am new to xlinx sdk i want to run a  c code which has simple some array operation in that .
when i run the code its going to disassembly.c before executing the loop .i am not getting any thing ,can any one help me to sort out of this problem. code i used to run is written below.
#include<stdio.h>
int main()
unsigned char arr[721920];// 0x5bc20
unsigned char arr1[721920];//0x5bc20
char ch ;
int i=0 j=0;
while(arr[i]!='0')
ch=arr[i];
ch=ch-(8*5-3);
arr1[j]=ch;
i++;
j++;
return 0;
hbucher
@geetha.diwakar Make sure you are compiling a Debug build. Put a breakpoint on the first line. Run Debug.
geetha.diwakar
thanks for your reply,
if i add a break point inside the while loop and started debugging ,after debug if i run the prgm  ,prgm not hitting to the break point directly it is going to return 0 and after that disassembly.c file .please help me to sort this problem.
hbucher
@geetha.diwakar If you move the declaration of arr and arr1 to above (outside) main What happens? I think you are exceeding stack size.
geetha.diwakar
i changed the array size and declared out of the main also same result
u can check my code.
unsigned char SendBuffer[71]={56, 00, 36, 01, 00}; //0x100ad4
unsigned char RecvBuffer[71];// 0x108024
int main()
unsigned char ch;
int i=0;
while(SendBuffer[i]!='\0')
ch=SendBuffer[i];
ch=ch;
RecvBuffer[i]=ch;
i++;
hbucher
@geetha.diwakar These are general clc++ questions, nothing to do with Xilinx products. You'd rather get more feedback from stackoverflow or reddit.com/r/cppquestions
