failed to download bl31.elf when downloading petalinux through JTAG
I'm using ZCU106 and PetaLinux 2019.1 and 2019.2.
I generated PetaLinux project and download bitstream via JTAG: "petalinux-boot --jtag --fpga", it outputs:
APU L2 cache is held in reset
Failed to download xxxxxxxxxxx/zcu106/images/linux/bl31.elf.
Both PetaLinux 2019.1 and PetaLinux 2019.2 gave the same errors. I also used Xilinx ZCU106 BSP, but got the same problem.
Other similar posts suggest using xsct to manually reset APU, but I don't know how to do that, it seems that I need to access
some memory addresses.
Did anyone encounter the same downloading error? Or could anyone point to me how to use XSCT to boot PetaLinux on ZCU106?
Thank you.
Re: failed to download bl31.elf when downloading petalinux through JTAG
Hi @zouyu930503,
Please check if you are setting the boot mode to the JTAG mode on your board.
Best regards,
Abdallah
Yes, the JTAG mode is correctly set.
I'm not sure if this is a bug of PetaLinux or something else. But when I manually reset APU, it works fine.
It seems that somehow the APU is not correctly reset when downloading files.
I followed this link:
https://forums.xilinx.com/t5/Embedded-Linux/ZCU102-APU-L2-cache-is-held-in-reset-petalinux-boot-jtag/td-p/936649
