fatal error: xwdtps.h: No such file or directory
I'm using Petalinux 2013.10 and Vivado 2013.4 on a Zynq 7020. I build my HDL bitstream without any issues. However, when I move over to the SDK and I try to build my project on SDK, I recently started having issues with this error. My coworker does not have this issue, nor did I have this issue until last week. I've tried the suggestions from AR# 54896 and various other forum posts (listed below) with no luck. Additionally, I have also uninstalled and re-installed Vivado 2013.4 + SDK Webpack edition. I attempted to add a path to the missing .h file with no luck as well.
Any help is greatly appreciated!
Errors I see:
make[1]: *** [wdtps_includes] Error 126 fs-boot_bsp C/C++ Problem
make[1]: *** [include] Error 126 fs-boot_bsp C/C++ Problem
make: *** [ps7_cortexa9_0/lib/libxil.a] Error 2 fs-boot_bsp C/C++ Problem
make: Target `all' not remade because of errors. fs-boot_bsp C/C++ Problem
make: *** [src/image_mover.o] Error 1 fs-boot C/C++ Problem
make: Target `all' not remade because of errors. petalinux_bsp C/C++ Problem
make[1]: Target `include' not remade because of errors. fs-boot_bsp C/C++ Problem
make[1]: *** [profile_includes] Error 126 fs-boot_bsp C/C++ Problem
make[1]: *** [xiicps_includes] Error 126 fs-boot_bsp C/C++ Problem
make[1]: *** [ttcps_includes] Error 101120 petalinux_bsp C/C++ Problem
make[1]: *** [xiicps_includes] Error 101120 petalinux_bsp C/C++ Problem
make[1]: *** [xdmaps_includes] Error 126 fs-boot_bsp C/C++ Problem
fatal error: xwdtps.h: No such file or directory image_mover.c /fs-boot/src line 93 C/C++ Problem
make: *** [ps7_cortexa9_0/lib/libxil.a] Error 2 petalinux_bsp C/C++ Problem
make[1]: *** [ttcps_includes] Error 126 fs-boot_bsp C/C++ Problem
make[1]: *** [xsdps_includes] Error 126 fs-boot_bsp C/C++ Problem
make[1]: *** [wdtps_includes] Error 101120 petalinux_bsp C/C++ Problem
make[1]: *** [profile_includes] Error 126 petalinux_bsp C/C++ Problem
make[1]: *** [standalone_includes] Error 126 petalinux_bsp C/C++ Problem
make[1]: *** [xdmaps_includes] Error 101120 petalinux_bsp C/C++ Problem
make[1]: Target `include' not remade because of errors. petalinux_bsp C/C++ Problem
Forum post's I've tried following with no luck:
https://forums.xilinx.com/t5/Embedded-Linux/Fatal-Error-ff-h-No-such-file-or-directory/m-p/417503/highlight/true#M7959
https://forums.xilinx.com/t5/Embedded-Development-Tools/Type-fatal-error-lwip-err-h-No-such-file-or-directory/m-p/488304/highlight/true#M32353
https://forums.xilinx.com/t5/Embedded-Development-Tools/Linux-SDK-fatal-error-xparameters-ps-h-No-such-file-or-directory/m-p/399141/highlight/true#M29695
https://forums.xilinx.com/t5/Embedded-Linux/fatal-error-string-No-such-file-or-directory/m-p/551883/highlight/true#M11448
Re: fatal error: xwdtps.h: No such file or directory
Does anyone have any suggestions on things to try? I'm still stuck on this issue.
hi,
would that be possible to share the hdf/xml that you are trying to export to software?
--hs
Sure - I've attached it.
Max
Has anyone had a chance to try out the .xml file in their SDK?
Max
This is still an issue for me. Can someone help?
Hi again,
I'm still looking for help. Is anyone able to help me here?
Max
Just wanted to check in again. Is there anyone who could give me some direction on how to resolve my issue?
