adrianf0
few drivers for a single IP module
In my top-level block design, I have a custom module. The custom module contains another block design which includes an SPI block and 2 other custom sub-block - each with its own address space and interrupts.
At the moment HSI creates the following PL device tree:
        amba_pl: amba_pl {
                #address-cells = <1>;
                #size-cells = <1>;
                compatible = "simple-bus";
                ranges ;
                CLICpix2_0: CLICpix2@43c10000 {
                        compatible = "xlnx,CLICpix2-1.0";
                        interrupt-parent = <&intc>;
                        interrupts = <0 31 1 0 30 1 0 29 1>;
                        reg = <0x43c10000 0x1000 0x43c20000 0x1000 0x43c30000 0x10000>;
I am aware of custom mdd and Tcl fils. However, how should I organize them, in order HSI creates the following device tree:
        amba_pl: amba_pl {
                #size-cells = <1>;
                ranges ;
                   receiver_0: receiver@43c10000 {
                           compatible = "xlnx,receiver-1.0";
                           interrupts = <0 31 1 >;
                           reg = <0x43c10000 0x1000>;
                  control_0: control@43c20000 {
                           interrupts = <0 30 1 >;
                           reg = <0x43c20000 0x1000>;
                  spi_0: spi@43c20000 {
                           compatible = "xlnx,xps-spi-2.00.a";
                           interrupts = <0 29 1 >;
                           reg = <0x43c30000 0x10000>;
Is is possible to address this case with HSI tool?
adrianf0
Although, as you suggested, I had to use hsi API and Tcl in order to achieve my goal, I haven't found a good existing example. Thus, as a reference, people with the similar problem may look for an inspiration in my code (link).
stephenm
The DTG (devicetree generator), won't support this use case. You would need to create your own driver to the devicetree that would add the nodes for your "nested" IP via hsi API in a tcl file. You should take a look at the simple driver such as the GPIO for guidance here.
You would get the devicetree from GitHub, make your changes, create patch, add patch to petalinux (assuming you are using prtalinux)
However, is this worth the effort? Would you not just be best creating the device tree manually?
adrianf0
 @stephenm, thank you for your reply.
Anyway, as I would like to have a clean and generic solution, I would go with a hsi patch rather than device tree written manually.
I know how to create a regular driver. However, my problem is creation of 3 device tree nodes for a single IP module. I have taken a look at gpio example but didn't find any inspiration there (one ip - one node).
stephenm
There would be no example of drivers with your use-case. You would need to get all the IP at the same hierarchy as your IP (so the same parent cell), then add the nodes for these.
adrianf0
ibaie
Hi @adrianf0,
Thanks for sharing your reference code, please mark it as solution ;)
Ibai
