Visitor vibhuthk
floating connection
i am getting this as warning in XPS and i dont know how to overcome this.
WARNING:EDK:4181 - PORT: Peripheral_Reset, CONNECTOR: proc_sys_reset_0_Peripheral_Reset - floating connection - C:\xps\Final_v1.mhs line 48
WARNING:EDK:4181 - PORT: FSL0_S_CLK, CONNECTOR: fsl_v0s_FSL_S_Clk - floating connection - E:\programfiles\14.7\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v8_50_c\data\microblaze_v2_1_0.mpd line 741
WARNING:EDK:4181 - PORT: FSL0_M_CLK, CONNECTOR: fsl_v0m_FSL_M_Clk - floating connection - E:\programfiles\14.7\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v8_50_c\data\microblaze_v2_1_0.mpd line 746
WARNING:EDK:4181 - PORT: FSL1_M_CLK, CONNECTOR: fsl_vcm_FSL_M_Clk - floating connection - E:\programfiles\14.7\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v8_50_c\data\microblaze_v2_1_0.mpd line 756
WARNING:EDK:4181 - PORT: FSL0_S_CLK, CONNECTOR: fsl_v1s_FSL_S_Clk - floating connection - E:\programfiles\14.7\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v8_50_c\data\microblaze_v2_1_0.mpd line 741
WARNING:EDK:4181 - PORT: FSL0_M_CLK, CONNECTOR: fsl_v1m_FSL_M_Clk - floating connection - E:\programfiles\14.7\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v8_50_c\data\microblaze_v2_1_0.mpd line 746
WARNING:EDK:4181 - PORT: FSL0_S_CLK, CONNECTOR: fsl_v2s_FSL_S_Clk - floating connection - E:\programfiles\14.7\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v8_50_c\data\microblaze_v2_1_0.mpd line 741
WARNING:EDK:4181 - PORT: FSL0_M_CLK, CONNECTOR: fsl_v2m_FSL_M_Clk - floating connection - E:\programfiles\14.7\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v8_50_c\data\microblaze_v2_1_0.mpd line 746
WARNING:EDK:4181 - PORT: FSL0_S_CLK, CONNECTOR: fsl_v3s_FSL_S_Clk - floating connection - E:\programfiles\14.7\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v8_50_c\data\microblaze_v2_1_0.mpd line 741
WARNING:EDK:4181 - PORT: FSL0_M_CLK, CONNECTOR: fsl_v3m_FSL_M_Clk - floating connection - E:\programfiles\14.7\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v8_50_c\data\microblaze_v2_1_0.mpd line 746
WARNING:EDK - :EDK - IPNAME: axi_7series_ddrx, INSTANCE:DDR3_SDRAM - Clock port 'freq_refclk' phase not checked because the MIG recommended value cannot be determined.
Re: floating connection
This warning can be safely ignored.
XPS left a connection for non-existent peripherals. The unused connection will be safely trimmed.
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
