ss_tech
generate pwm signal
hello
iam needed to generate pwm signal in edk program using timer on spartan 3e. what steps to do that?.
thank you................................
austin
ss,
Step 1:  go research (read) about programming a PWM control in verilog, or VHDL (your choice).
Step 2:  read about performing PWM in c code.
Step 3:  decide if the c version is fast enough, if so, write your pwm controller in c, and use gpio for the signals.
Step 4:  if the c code is too slow, or can not provide the resolution, then create the design in RTL (verilog or VHDL).  Add the RTL code block as a peripheral in EDK, and either drive it through a memory mapped interface, gpio, or a FSL off the AXI bus.  You may also implement the PWM controller entirely in logic, and not use EDK at all, if you do not need the processor system.
Austin Lesea
Principal Engineer
Xilinx San Jose
rajasekarsmvec
Hi i want to generate Sinusoidal Pulse Width Modulation scheme using Xilinx System Generator. Is it Possible to generate through System generator With Sinusoidal signal of 50 Hz frequency and Triangular Signal of 3kHz frequency .
ss_tech
hello
Iam want to use timer core to generate pwm signal as found in data sheet of xps timer and using functions found in timer to generate signal.
thank you for reply..........................
hgleamon1
ss_tech:
1. Read the XPS Timer datasheet.
2. Add the Timer IP to your XPS project.
3. Write some C code for the MicroBlaze to manipulate the Timer IP registers in accordance to their description and your requirements.
Howard
"That which we must learn to do, we learn by doing." - Aristotle
ss_tech
hello
iam  adding xps timer and using functions found in timer and using configuration the timer as the data sheet and get the result on the scope as below but the result is correct or not ?.please
hgleamon1
I don't know what your requirements are, so I can't comment on whether it is "right". It looks like you have generated a PWM signal but I can't really see what the timebase or signal measurements on your scope shot are.
ss_tech
PWM_PERIOD = (TLR0 + 2) x PLB_CLOCK_PERIOD
PWM_HIGH_TIME = (TLR1 + 2) x PLB_CLOCK_PERIOD
when using this do not appear on the scope
as the work correct or not? please
ss
