jyjo2
generated FSBL elf size issue in XSDK 2019.1
Development Environment - XSDK 2019.1
Evaluation Board - zcu102 board
After setting to release Configuration of FSBL Application Project,  I build it.
The generated elf file size is about 400KBytes. According to TRM documents, FSBL elf size must be under 168KBytes.
I tried to rebuild this project using XSDK 2018.2. The generated elf file size is about 120KBytes.
How can I generate FSBL elf file under 168KBytes?
abouassi
Hi @jyjo2,
Please refer to the following thread.
Best regards,
Abdallah
