rwehumbiza
gprof using Zynq-7 ZC706
Hi Community,
I am trying to do a software profiling using Xilinx SDK, I have Zynq-7 ZC706 development board, I followed the instructions on how to do it, when I ran my application software it stuck in FSBL at very beginning,(it stuck in boot.s loop) I think it doesn't know where to go next, If I remove all profiling settings the software runs fines, just this morning I read " gprof based profiling is supported only by XMD and is not supported for new Xilinx devices" From Xilinx SDK help I am using, is this statement true for the type of development board I am using?.
pvempati
Hi @rwehumbiza,
Which release you are trying? and Gprof profiling is supported in system debugger also.
Also post your project/program so that we can replicate here.
Please try the below chapter mentioned in SDK help.
Setting Up the Software for Profiling
Thanks & Regards,
Praveen Kumar. V
rwehumbiza
Hi Pvempati'
I am using Xilinx SDK Release Version: 2015.4 and vivado 2015.4, also I am using a system debugger. I can not post a project/program here, I can show you what I have in Project Explorer, see image below,  I have fpga_top_hw_platform_0, fsbl files, fsbl_bsp files, ssbl files and test (application), This is what I did,
1. Enabled enable_sw_intrusive_profiling field to true
2. On the drivers item, under cpu driver. I Added the -pg flag to the extra_compiler_flags option.
3. In the build settings, I enabled profiling (-pg).
The application build Ok, but when I tried to run it, It get stuck in initial startup code for the Cortex A9 processor, well before my application is called. I thing it has to do with the BSP settings for the processor.
rwehumbiza
Hi Pvempati,
attached file is the code where the start up hangs up.
