hdf file tampered while lauching vivado 2016.2
I am trying to open a vivado project created in 2016.3 from vivado 2016.2.
While launching SDK, I get an error as "hdf file is tampered".
how to resolve this?
I referred this link https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-2014-2-on-linux-Change-Hardware-Platform-Specification-fails/td-p/501066
and tried to create a new hdf. But I am not sure how to create hdf. Is there some reference to resolve this probelem?
Thanks, Aj.
Asan.
Re: hdf file tampered while lauching vivado 2016.2
@ibaie
Yes, the project had a hdf file.
The error got resolved by deleting the already created project_1.sdk folder. after deleting 'export hardware' worked fine and able to generate hdf.
Thanks for your response.
Hi @ajasan
Not sure if you have an HDF file from 2016.3 or vivado project.... Can you expalin it bit better?
To generate a HDF file you just need to export the hardware platform file from Vivado (File -> Export hardware)
Ibai
@ibaie
@ajasan
Great to hear that you finally solved the issue.
I'm not sure why you file was detected as tampered but SDK prevent those HDF files to be used just to prevent errors or bad usages. (Usually unzip the HDF file, modify and the repackage).
Please mark the issue as solved for better tracking of the issue
Ibai
