hdf vs bit file
Can someone please shed some light on the difference between hdf and bit file ?
I can create new hw spec project by using the hdf only. Does it mean that hdf binary includes the bit information inside ?
Is it that the hw project generates from hdf new bit and new bmm file ?
hdf ---- hw project --> new bit and new bmm file
Thank you,
Ran
Scholar stephenm
Re: hdf vs bit file
The hdf file is a container file ( like a zip) that contains the files used in SDK. If you selected the include bitstream option in Vivado when exporting. The hdf will contain the bit file.
You can right click on the hdf and unzip it, or use the command open _hw_design file name.hdf in SDK command line
Note: if in 2015.1, the command is SDK open_hw_design file name.hdf
Scholar stephenm
Re: hdf vs bit file
Re: hdf vs bit file
Re: hdf vs bit file
It seems the thread is duplicated at http://forums.xilinx.com/t5/Embedded-Development-Tools/Failure-in-sdk-Unable-to-read-FPGA-Bitstream/td-p/602252
Praveen
Re: hdf vs bit file
That's right, it is duplicated.
I hope the other thread will have a solution.
Ran
