heap and stack in microblaze
 I am a little confused about the heap and stack in a microblaze application. I am not sure how to figure out how much memory to allocate in each category. What does it depend on? Thanks,
Amish
Anonymous
Not applicable
hi
you may define it in compiler options just below default linker script .bt is it the right way or not that i dont know..even i face the same problems..if you have solve this than pls post me...
amit
