help with uartlite function
i like to receive integer from uartlite ( 1 to 30 ) who know the function used in C to do the work ??? i see the xilinx drivers but i find receive byte by byte !!!! please the function AND HOW TO USE IT !!
thx,
regards
After you receive the bytes from UART, you may store it in an char array and use the atoi() function to convert it to an integer. Would this work for you?
Some examples of how this function is used.
http://www.codecogs.com/reference/c/stdlib.h/atoi.php
http://www.cplusplus.com/reference/clibrary/cstdlib/atoi/
Hope this will help you.
-Yan Shun Li
