Visitor fatimajoon
hi, I wanted to simulate an ipcore with xps. I compiled...
hi,
I compiled the simulation libraries,
then I generated simulation HDL files.
but when I select the launch HDL simulator
I enconter the following:
make: nothing to be done for "simmodel'
best regards
Re: hi, I wanted to simulate an ipcore with xps. I compiled...
XPS is makefile based.  That means that it should only run a compiler, or generate netlists if something has changed since the last time you ran a command.
It looks like you have previously run the simulation generator (simgen) to generate the simulation models for your system.
Launch HDL simulator should launch your simulation tool (ie Modelsim, Ncsim).
It would be worth checking that the executable for your simulator is in your path.  Check /doc/usenglish/help/platform_studio/html/ps_p_sim_setting_up_modelsim_for_using_smartmodels.htm or /doc/usenglish/help/platform_studio/html/ps_p_sim_setting_up_ncsim_for_using_smartmodels.htm to see if that helps.
Kris Chaplin
Xilinx UK
