dmitril
how to add symbols for a .ko module to System Debugger on Xilinx SDK 2016.4?
I followed this
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/SDK_Doc/tasks/sdk_t_tcf_attach_debug_linux_kernel_tcf.htm
and this
https://www.xilinx.com/support/answers/67325.html
with System Debugger on Xilinx SDK 2016.4
but I cannot load symbols for kernel module such as virtio_rpmsg_bus.ko
As that last link said, I added to Path Map:
Source: virtio_rpmsg_bus
Destination: /home/me/petalinux_kernel/drivers/rpmsg/virtio_rpmsg_bus.ko
I also added to Symbol Files
/home/me/petalinux_kernel/vmlinux
Now I can see symbols for kernel routines, for example I can add expression "&printk" and it is displayed correctly, also breakpoint on printk works.
But if I add expression &rpmsg_send_offchannel_raw or set breakpoint on rpmsg_send_offchannel_raw or rpmsg_fini, none of them work.
I also tried adding /home/me/petalinux_kernel/drivers/rpmsg/virtio_rpmsg_bus.ko to Symbol Files - does not work either.
So, the question is: how to add symbols for a .ko module to System Debugger on Xilinx SDK 2016.4?
Thank you
sadanan
dmitril
Sorry, these links that you posted missing crucial information.
They say:
Click the Path Map tab to set the path mappings for the selected debug configuration.
Click Add to insert the kernel module.
What does this mean? How can you add the module? What values should you specify for various fields in that dialog?
I followed
and it is more descriptive,
but still does not work.
So, please, give me exact steps to begin debugging virtio_rpmsg_bus.ko on SDK 2016.4
Thank you
dmitril
Is it possible to get an answer to this question
or is there some other support channel?
bminier
Hi dimitril,
Did you succeed to debug kernel module ?
As you, I tried to follow this post https://www.xilinx.com/support/answers/67325.html but I'm not sure of the path to setup as path mapping.
It doesn't work.
Thanks for your help.
shabbirk
Hi @dmitril @bminier
Try building the petalinux after selecting image packing configuration to initrd or sdcard, instead of default initramfs. This is expected to generate proper debug symbols
petalinux-config -> Image Packaging Configuration ---> Select INITRD
Best Regards
Shabbir
