anusharanga
how to connect Zynq board in jtag mode
hello friends
May  i know the settings of zynq zc702 board .I confused a lot
what i put configuratioon for JTAG settin
I used SW10 ---10
sw16  (5 switches) are in right
in this configuration all leds are on green
I try to download the bitstream and dumped in board . The application is not running even printing also not done . what is the problem but if i put in defalt mode that is BIST mode . My application is running perfectly but my intension was to run my SoC bitstream instead of BIST bit stream.
joy1887
have a look on UG926
regards
umamahe
Please verify all default jumpers and switches. The ZC702 Getting Started Guide (UG926) lists the default Jumper and Switch settings in Table 1-1 and Table 1-2. These default Jumper and Switch settings are also shown in Figure 1-3 of the user guide,
The following AR http://www.xilinx.com/support/answers/54012.htm helps to debug if any board problem exists
