how to generate bsp files in cmake
Hi:
    I'm a driver software engineer but a new starter on using the xilinx tools.
    I can generate the bsp files from the hardware "*.hdf" files, by using the SDK IDE.
    But now I need to integrate the system to our development environment. So, I need to generate the HW&BSP files base on given *.hdf file, under the cmake cross compile environment. I try the xsct but the command like "createhw" and "createbsp" can be runned on the xsct environments, but cannot runned on the CMAKE files. And I cannot found the resolve method yet by through the google....
    Can you kindly give me a suggestion how to resolve that? A example show how to do is perfect. Thanks very much!
hi,
did you get a chance to check this link?
--hs
Hi, were you able to create an appropriate cmake file? If so, would you mind sharing it?
