Visitor al3krab82
how to make the Microplaze reading the input from text file by using EDK
Dear All...
Anybody can help me, i wana read my input to microblaze via input text file, so anybody have example or the protocol to do that..
thanks alote.
Re: how to make the Microplaze reading the input from text file by using EDK
Hello.
You can create a loop back process. Make a system of UART and microblaze. Configure UARTs baud to 9600 without parity. Use UARTs API to send and receive data from PC.
Compile the design and open Hyperterminal on PC and configure it for the settings you used in your system using com port. Then you can send input text file from PC and you can verify the same on hyperterminal as it will be a loop back process.
Best of luck.
Unlimited in my Limits.
