Observer amitcrathod
how to read/write data from FSL?
hello!!
i am new to microblaze..pls can you guide me what are the functions to read write data to/from FSL link.?
Re: how to read/write data from FSL?
The functions are defined here:
%XILINX_EDK%\sw\lib\bsp\standalone_v2_00_a\src\microblaze\fsl.h
And described here:
%XILINX_EDK%\sw\lib\bsp\standalone_v2_00_a\doc\standalone_v2_00_a.pdf
Other useful information here:
%XILINX_EDK%\hw\XilinxProcessorIPLib\pcores\fsl_v20_v2_11_a\doc\fsl_v20.pdf
%XILINX_EDK%\hw\XilinxProcessorIPLib\pcores\microblaze_v7_10_d\doc\microblaze.pdf
[Note: file paths valid for EDK 10.1.03i - you may have to adjust to the latest available version in your installation if you are using a different EDK version as it may affect the path]
bt
Message Edited by timpe on 03-26-2009 10:15 AM
And described here:
bt
thank you very much!! it helps perfectly.
