jack.roundhouse
how to recover from Invalid DAP ACK value: 0 on linux?
I am running tcl commands from xsct in non-interactive mode.
The script fails, causing the board to enter an error state:
1. I enter this state when running the script in xsct. I am receiving the same error when using XSDK -> run as -> launch application
2. Afterwards, I power cycled the board, closed all consoles and XSDK, the error remains
3. I can recover from this state rebooting the host OS
How can I recover from this state? I presume there is some process running that I can kill?
thank you
ibaie
Hi @jack.roundhouse
It seems strange the fact that you need to reboot the host to recover from the issue :O
Could you give bit more details about your use case in terms of which device are you using, the kind of script you are using... I mean is the XSCT script accessing to the reported memory address? is the application doing that?
Ibai
jack.roundhouse
XSDK is accessing the reported memory address.
1. I was causing a DAP ACK event with the script I created (xsct, non-interactive). The script was clearing the FPGA configuration before programming the ARM processor, but the setup was missing several modifications for proper operation.
2. After this I switched to XSDK.
3. I was able to burn the FPGA but unable to program the processor.
4. In this state, after rebooting the host OS, launching XSDK and burning the FPGA I was able to run same application with no errors.
5. These steps could be repeated when using the script to cause a DAP ACK.
# hw setup
- OS: Ubuntu 16.04
- board: Zybo
- device: Zynq 7010
# sw setup:
- XSDK 2017.4
The run configurations I used had "Run ps7_init" and "Run ps7_post_config" set. The application used was the default hello world for C.
# further details
Without rebooting, what I tried without success to recover was
- power cycling the board
- reconnect the USB programming port
- closing all applications, there where no shell commands, xsdk or xsct processes listed in the system monitor.
- restarting XSDK.
The minimum steps I used to recover were
- rebooting host OS
- reset entire system
Unfortunately I don't have the original script anymore. Today I induced a DAP ACK but have been unable to replicate the steps described above. When I have more findings I can report them here.
