how to route SPI0 MIO pins to EMIO
I am using spi0 in my project.........i created HDL from vivado 2016.2 with SPI0 MIO pins as EMIO pins...do i need to change the program in SDK for SPI0.......code for spi0 for mio pins work for spi0 for emio pins???can i check spi CLOCK,MOSI,MISO,CS using ocilloscope???i routed spi0 emio pins to other pins on the board(using pinpackage in vivado<zynq bank 34>)..please let me know.i am checking spi0 signals but not getting signals for my code????
Hi @geetha.diwakar,
> Yes. The driver controls the SPI controller so whatever where the output is going
> I guess
> Did you have any signal when using MIOs?
Florent
Hi @geetha.diwakar,
> I guess
Florent
>thank you
I guess
>i am checking but not getting any signals on spi clock and mosi.(i dint connect any spi slave to zynq).......
but codes for spi is running without any failure(XSCT_FAILURE)....please help me
Hi @geetha.diwakar,
I am checking but not getting any signals on spi clock and mosi.(i dint connect any spi slave to zynq).......
> You might need to have a slave. I do not fully remember how but you might need to have the line in high impedance or something...
Florent
>yes......but i donno whether mio program will work for emio in sdk??
>i am checking only spi clock and MOSI.....not MISO
HI @geetha.diwakar,
> It should be working.
Florent
