how to run program in Linux platform for Vitis ?
Hello sir/madam,
I am trying to run a program using Linux Platform in Vitis for the ZCU102 board but Not running properly.
Please tell me the procedure for running the program in detail.
Hi Rakesh,
If I understand you clearly, are you trying to create a Linux application in Vitis on a zynq ultrascale device? If yes, here is a link where you can find detailed information on creating a Linux user application in Vitis on a Zynq UltraScale Device.
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Creating-a-Linux-user-application-in-Vitis-on-a-Zynq-UltraScale/ba-p/1141772
Ashwini
Give kudos if helpful. Accept as solution if it solves your problem.
thank you for information Ashwini Miskin
I have one more problem is there
How to connect Ethernet to ZCU102 using Vitis and Vivado?
how to send data through Ethernet and check data rate?
Glad the blog helped.
For the ethernet. Do you want to do this in Linux, or Baremetal?
Can you make sure that the FSBL is passed the XPS_BOARD_ZCU102 symbol:
https://github.com/Xilinx/embeddedsw/blob/master/lib/sw_apps/zynqmp_fsbl/src/xfsbl_board.c
If you are using Linux, then you should use the ZCU102 BSP as this will have the correct device tree with the PHY node.
Then you can use tools such as iperf (enable this in petalinux-config -c rootfs) to measure the data rate.
If you are using baremetal, then you can use LwIP:
https://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
present I want do it in Linux.
please tell me about both procedure of Linux and Baremetal.
