binbinyantai
how to specify the debug emulators in different sdk project?
hi every:
i want to debug two sdk project at the same time .one emulator for one project.
i open two sdk environment,and open the sdk project seperately in the different sdk environment.
but ,i can not specify which emulator i use to debug .
how to fix this problem? i use sdk2017.4
sadanan
When you have two instances of SDK, each instance will launch its own emulator, and connect to it. You do not have to specify the emulator instance to which you want to connect to. Are you seeing any problems with this?
binbinyantai
but how can i know which sdk connet to which emulator to debug?
two sdk instance in one virtual machine.
i can not know which  sdk  debug using which emulator?
two sdks  all debug one device using one emulator
