Visitor shenhuanghui
how to use EDK10.1.03 to test Synchronous Dual-Port RAM read and write?
hi, i have connected 256K*36 Synchronous Dual-Port RAM external to Virtex4.
and i want to use EDK10.1.03 to test Synchronous Dual-Port RAM read and write.
Could anybody tell me how to do? Thanks!
Visitor sachingorkhe
Re: how to use EDK10.1.03 to test Synchronous Dual-Port RAM read and write?
Hi shenhuanghui,
Are you using any Xilinx dev. board to test on-board SDRAM ?
If so then after build your system into EDK, you need to import your TestApp_Memory application to SDK and use the predefined example for SDRAM read write check. If the application is different what you are expecting then you need to update this C code and edit the same and then perform a simple read and write transaction for this SDRAM.
Hope this helps you,
SACHIN
