Observer ziseouranle
how to use the mcb with xps?
I'm using mcb in xps(axi4),but I can not make the ddr2 work.Can someone know how to use the ip of mcb with xps?And give me some information about it,step by step is the best.Thanks!
Re: how to use the mcb with xps?
Please go through the attached step by step tutorial. It will help you to build the system.
Praveen
Praveen
Thanks,I will try it.
Hi,I try it like the PDF,when I create a "Hello World" project,it works,but if I creat a "Memory Test"project,it returns "-1",which means 'failed",do you know what's wrong about it?And,if I use "MIG" directly,not in xps,the ddr3 works well. Thanks
I will test at my end and let you know.
Praveen
