Scholar trenz-al
hsi:generate_target -compile fails on app
I am trying to make a script that:
1) creates a template application, say "hello_world" without compiling it
2) modifies the bsp parameters
3) compiler the application
EVERYTHING works well, except the last step
hsi::generate_target -dir $appdir -compile -verbose app
this line just RETURNS without doing anything, and not giving any message either!!
well, actually the line causes FATAL error in HSI, that causes FULL lockdown and freeze on next command, no matter the next command would be, so as example
puts [hsi::generate_target -dir $appdir -compile -verbose app]
this would never return, and I would need to KILL HSI process from task manager..
Scholar pratham
Re: hsi:generate_target -compile fails on app
@trenz-al 2015.3 HSI? Can you post your script here?
-Pratham
Scholar trenz-al
2015.2, but 2015.3 it think makes same error
the second puts after the last generate_target always crashes!
cd workspace
set appdir hello_world
set hw [hsi::open_hw_design test_board.hdf]
set cpu [get_cells -filter {IP_TYPE==PROCESSOR}]
set swdesign [hsi::create_sw_design system -proc $cpu -app hello_world]
hsi::current_sw_design $swdesign
# generate hello world, but do not compile!
hsi::generate_app -hw $hw -sw $swdesign -app hello_world -proc $cpu -dir $appdir -verbose
# compile BSP, works OK
hsi::generate_target -dir $appdir/hello_world_bsp -compile -verbose bsp $swdesign
# CRASH, eg does nothing
hsi::generate_target -dir $appdir -compile -verbose app $swdesign
puts "This does always get printed"
puts "if generate target (app) is called, then GARBAGE is printed here, and HSI FREEZE CRASH!"
Scholar stephenm
The line (below) looks incorrect.
Should this not be:
hsi::generate_target -dir ${appdir}/hello_world_bsp -compile -verbose bsp $swdesign
Also, if you want to compile the bsp, then use the generate_bsp. However you dont need this as you
are using generate_app (the bsp will be built here too). So, you can just add the -compile here.
For example:
cd workspace
set hw [hsi::open_hw_design ../design_1_wrapper.hdf]
set cpu [hsi::get_cells -filter {IP_TYPE==PROCESSOR}]
hsi::generate_app -hw $hw -sw $swdesign -app hello_world -proc $cpu -dir $appdir -compile
This will create the executable.elf for you.
Scholar trenz-al
this is NEEDED, I have no issues creating and compiling in one-go, but this is not an option.
As soon as create template app without -compile, and try to compile it later, then HSI CRASHES
Please help!
Scholar stephenm
oh, right. I see. I never use this generate_target API. I just exec the make files (which is essentially what this should do if it worked i guess)
I have attached an example script that I created that builds the socket_app in xapp1026. This uses HSI to build the hw_platform, bsp (changes the bsp settings), sets the compiler options, then builds the elf.
Note: There looks like a bug with the APP_LINKER_FLAGS though. I couldn’t get this to work.
So, I worked around this by setting it manually in the makefile.
To test, download the zip, and run the script.tcl from XSCT (you will need to navigate to the unzipped folder)
Or, just see the proc build_ws as this is the main proc.
In the mean time, I ll check on this generate_target API to see what this is meant to do.
Scholar trenz-al
thanks I try
I can change BSP settings, but what I need todo is:
change one .h in the template appliction, to change the srec_spi_bootloader
flash load address, the only way to todo would be that the compile is invoked LAST, but this CRASHes :(
Scholar stephenm
Do you have the hdf file?
I can create a script for you
Scholar trenz-al
I have, but the problem is generic, not related to specific design.
So if you take any HDF with microblaze, and try to create say hello_world
while NOT specifiying the -compile at the creation of the template
and if after that you can run generate_target
that compiles the template app, then the problem is solved.
I have 2 workarounds, that I do not like:
1) I make local copy of the template_app, and use -compile as "one pass"
2) I run SDK make :(
I do not like them.. so I am trying to fix the HSI bug..
Or, let me say the reason, goal:
do_it_all.tcl
1) create project, export hwdef
2) create_app, build elf
3) assot .elf
4) build bitfile with the elf merged into bram by vivado, not SDK (there is SDK bug that erases timestamp in bit file)
ideally this should run as single TCL script
I can currently do it as sequence of batch files that execute different TCL in a sequence
Your script MANY thank you already ! really, thank I looked and there are several nice tricks inside..
Scholar stephenm
I tried this real quick. My script is attached. I used a stock SPI KC705 design that I had on my machine. This creates the project, and it manually changes the blconfig.h to change the baseaddress (I guessed it was this you wanted changing??). I then use the make to build the ELF:
To test, just download the zip, and source the script.tcl:
Scholar trenz-al
you are using my workaround 2, what I also wanted to avoid. with
make
there are no issue, it works, yes.
but I assumed the generate_target should also work, as generate_target works for bsp, but not for app, CRASH
thank a lot again, for trying and helping and script example, I can only give kudos online.. so here you go again..
Scholar stephenm
For now it seems to be the only workaround. I'll check up on the issue to see what's wrong.
Scholar trenz-al
Ok, yes seems so.
I will try once one 2015.4 just got it installed, but I guess the issue persists..
Scholar stephenm
Unlikely to be addressed here. But worth a shot since you are installing anyway
