joancab
Advisor
Advisor
hw parameter completely wrong
Crazy. I updated some hardware, built it, exported it to SDK (2018.3), cleaned the sw project, everything fine then it hangs when running on the board.
Looking at the code I found that hovering over that parameter it shows (and presumably uses) that address (8002_0000) but when going to the source (ctrl-click) -ta-dah- it shows a different value (8003_0000).
Both cleaning the whole workspace and rebuilding the bsp didn't help.
joancab
Advisor
Advisor
After re-building the hw and re-exporting, the issue is gone... so I assume I may have exported it somewhere else before, instead of into the proper folder (?)
But anyway the above doesn't explain why the hover text doesn't match what the link goes to.
