importing custom AXI DMA controller into EDK13.2
I created a AXI DMA controller, which is similar to Xilinx AXI-4 DMA. Unfortunately at AXI stream interface I need to process TUSER signals, so I implemented my own version (for school project performance doesn't that matters).
Anyways now in EDK13.2 when I trying to import my core using CIP wizard it is not recognizing the AXI stream interface. For MPD file (attached), i looked at Xilinx AXI DMA core. But still it is not working.
should  i install EDK13.3?? or is there any other work around...
regards
