yetanotherid
#include <complex> fails?
Hopefully this is just me being dumb, but this:
#include <complex>
generates an error in SDK 2018.1:
In file included from c:\xilinx\sdk\2018.1\gnu\aarch32\nt\gcc-arm-none-eabi\arm-none-eabi\include\c++\7.2.1\complex:45:0,
                 from ../src/dma_test.cpp:4:
c:\xilinx\sdk\2018.1\gnu\aarch32\nt\gcc-arm-none-eabi\arm-none-eabi\include\c++\7.2.1\sstream:166:11: error: macro "str" requires 2 arguments, but only 1 given
       str() const
What's going on here? In all my searches I haven't found someone else with this problem, which is why I feel like I must be doing something silly.
(C++ project, standalone OS, ARMv7 toolchain)
yetanotherid
@ericv, @zyanwu, thanks for your suggestions! Here is the problem and solution:
This generates compiler errors:
#include "xaxidma.h"
#include <complex>
This compiles successfully:
#include <complex>
I stepped down into the rabbit hole of includes, and found that the culprit is somewhere within "xpseudo_asm_gcc.h". So it seems that some macro in there is clobbering something in the GNU STL. From this I take the lesson that all non-Xilinx includes should be #include-d first.
ericv
@yetanotherid
what about these 2 characters:
".h"
zyanwu
Try putting that header at the top of the include list.
Make it the first header to be included
yetanotherid
#include <complex>
#include <complex>
