Newbie nikos.al
installing XBD file from HiTech Global
Hello.
i have the following problem.
i am trying to install the xbd file that came with the board (from HiTech Global).
The EDK recognizes the board and i can successfully create a new project.
After that everything i try to do causes a fatal error.
More specifically, the first thing i tried to do and after that the error occured is to click on  "Project Options".
the error is the following:
"Fatal_Error:GuiUtilities:Gp_Application.c:590:1.20 - This application has discovered an exceptional condition... "
any help please??
thanks,
Nikos
Tags (4)
Newbie nikos.al
Re: installing XBD file from HiTech Global
no need to bother.
there were files missing from an ISE subdirectory that caused that error..
nikos
Newbie nikos.al
no need to bother.
nikos
