Observer inftimer
interrupt controller has no output
My EDK version is 12.3,I use spartan6(xc6slx484fgg-45t-3);the intc 2.01a has two interrupt source,one is external pin(connected to tms320c6455's GPIO),the other come from an counter 's the last bit,such as bit[26] for a 27bit counter;and the signal can be snapped by chipscope,but the interrupt controller has no output when the input has became to "1" ; but when the gpio is become high, the intc's output is high.I don't know why .
Observer inftimer
Re: interrupt controller has no output
come from the last bit of an counter ,such as bit[26] for a 27bit counter;and the
the input became to "1" ; but when the external pin (which connected to the intc's
input port) is become high, the intc's output is high.
Would that be possible to share the MHS of your system? This is an Embedded post, i will move this to Embedded Tools board
--Hem
Observer inftimer
thanks for your reply! this is my MHS file,and the gp9_logic_int is a counter,it's output connect to the intc2.0
Scholar stephenm
Hardware looks ok, can you show your application so can make sure that you are enabling the intc correctly, and setting up the interrupts on the intc correctly too
Observer inftimer
hi! thanks for your reply,now I rebuild the intc project and the main file was fellow below;
