interrupt issue with and without trigger in ILA
I am trying to run a AXI I2C application on zynq 7000 platform in SDK debug mode. Im facing a weird issue with the ILA and interrupt.
When i trigger for I2C interrupt signal and run the SDK application in debug mode I see the interrupt is generated and everything works fine but when I run the application without trigger the interrupt in ILA, I dont see any interrupt and the application gets stuck waiting for the interrupt. Has anyone come across such issue with ILA?
Thanks & Regards,
Bhavya K
The ILA is a relativly passive thing,
      its 'just' a load .
Are you fully constrained, and meeting timing ?
Try adding two input register delay  to the ILA ,
   it on the first menu of the ILA core.
this helps with timing constraints.
HI,
Its a xilinx provided AXI I2C core, so i didn't really constrain anything other than clock and there are no timing violations. And moreover it works only with ILA triggered, which is really strange.
How would this help? We will be trying to remove ILA at the end of the day and if it doesn't work without that we don't have a solution.
