invalid application of 'sizeof' to incomplete type 'struct sockaddr_in'
  We've upgraded from 8.2 to 10.1 to get the lwip 1.3 which is supposed to fix some etherenet lockups.
   We're using xps_ethernetlite
   When we compile, we are getting an interesting error in the following function:
 error: invalid application of 'sizeof' to incomplete type 'struct sockaddr_in'
static struct sockaddr_in remote_host_addr;
int send_udp_pkt( char *buf, int len )
    return lwip_sendto( udp_out_sock, buf, len, 0,
        (struct sockaddr*)&remote_host_addr, sizeof(remote_host_addr) );
Our "includes" are at the end of this message.
  I have tracked the  definition of sockaddr_in all the way through the header chain, and it _is_ complete.  I'm also not getting any errors for undefined header files.  _All_ header files are being found.
  Any clues?
thanks,
wade
#include "xparameters.h"
#include "xbasic_types.h"
#include "xstatus.h"
/* lwIP Includes */
#include "lwip/sys.h"
#include "lwip/ip_addr.h"
#include "lwip/sockets.h"
#include "lwip/memp.h"
#include "lwip/netif.h"
#include "lwip/tcpip.h"
  Doh!   I found it after 2 days of looking!
  The lwip 1.30 configuration screen had "RAW_API" chosen!  It needed to be SOCKET_API.
   The interesting thing is that the error message was so far out in left field, it didn't register.
   ALSO, the default BSB for a PPC xps_etherenetlite does not wire in the xps_intc controller!
Sounds odd. Could you add -save-temps to your compile flags for the application, and post the resulting .i file?
