annosauer1
iostream problems
Vivado 2018.3, Zynq UltraScale, using EIGEN library
The following program works perfectly fine in MS Visual Studio
#include <iostream>
#include <Eigen/Dense>
using Eigen::MatrixXd;
int main()
  MatrixXd m(2,2);
  m(0,0) = 3;
  m(1,0) = 2.5;
  m(0,1) = -1;
  m(1,1) = m(1,0) + m(0,1);
  std::cout << m << std::endl;
But in Vivado SDK  I get the following error messages
'std::log1p' has not been declared
'std::round' has not been declared
This is clearly related to the iostream functions.
The Eigen library apparently use some "newer" iostream features
I have tried to add
-std=g++11
//or
-std=g++0x
(as was suggested in some posts) to the compiler flags (Properties/Settings)
just to get another error message
Cannot find -lstdc++11
Has anybody ever successfuly used the EIGEN library in VIVADO SDK and what compiler flags do I have to set or
what do I have to do to make this work?
THANKS
annosauer1
After a few hours of trying all sorts of silly things...
First my application is obviously a lot more complex than the example above.
I am using freeRTOS, lwIP and the Eigen library  and the application is C++.
Mixing C and C++ has its own unique problems... however
1. Properties/Settings/C/C++ Build/ARM v8 g++ compiler/Directories..... add  <path to Eigen library>
2. Properties/Settings/C/C++ Build/ARM v8 g++ compiler/Inferred Options/Software Platform/   .... Software Platform Inferred Flags ... add       -std=g++11
3. Then you must add the include files to the Eigen library BEFORE everything else. (only took me 8 hours to figure this out).
4. These are my other properties settings...   for freeRTOS and lwIP
Properties/Settings/C/C++ Build/ARM v8 g++ linker/Inferred Options/Software Platform/  .... Software Platform Inferred Flags ... add
-Wl,--start-group,-lxil,-lfreertos,-lgcc,-lc,-lstdc++,--end-group
-Wl,--start-group,-lxil,-llwip4,-lgcc,-lc,-lstdc++,--end-group
5. in FreeRtosConfig.h you may want to change a few default values
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 16777216 ) )
6. Then the lwIP default settings are also good for nothing, just copy the settings from one of the provided demo programs
What tripped me up was:
Under tcp_options /  tcp_snd_buf  the maximum value is 65535   NOT   65536 (as I had to find out the hard way)
good luck
xilinxacct
Instructor
Instructor
@annosauer1
Here is one thing to try... #include <cmath> before including Eigen/Dense
Hope this helps
If so, please mark as solution accepted. Kudos also weclomed. :-)
annosauer1
good luck
annosauer1
Thanks for reply, but this was not it
annosauer1
@xilinxacct
Thanks for the reply, but this was not it
annosauer1
Sorry folks, the fingers were faster than the brain
In my solution, it should read
  -std=c++11
and NOT
-std=g++11
 This will give you acompiler error
