ip4addr.h
I am getting error in ip4addr.h file. Please suggest what can be issueip4error.PNG
Hi @sin
To allow the community to assist further, can you give more information on the failure? Is the source related to the failure part of a specific IP? Is this a Xilinx or custom IP? Can the text of the console failure be added.
Hi @sin
Unfortunately, an image is not what I was looking for. Can you upload the workspace export, so the behavior and logs can be reviewed?
