issues whit JTAG connection into vivado labs
our configuration is:
* vivado labs edition 2018.3
* JTAG probe Xilinx platform cable USB II
* custom board with Zynq UltraScale+ MPSoC Family EV with linux running on APUs (2018.3)
Into vivado labs when connecting to the target (open hw manager --> open target --> auto connect) we observe:
* a linux freezes
* a soft reboot
* sometimes (but very rare) the process is OK, linux is still running and we can use vivado labs tools to trig on ours events as expected
In linux freeze case, the JTAG probe LED is green and the JTAG connection is viewed as OK from vivado labs
(Our JTAG connection is OK: we use it to perform DDR memory tests into bare metal app on APUS and RPU)
Hi @axel_lagrange
It seems you might be facing the following issue:
https://www.xilinx.com/support/answers/69143.html
Ibai
Hi @axel_lagrange
Ibai
thank you Ibai: we can now use the JTAG without freezing linux
