Observer zrh0913
issues with rs232 interrupt mode
Hi, all,
Thank you for answering my previous questions, now, I am going very well with FPGA-based controller design.
But with one question,  I think the interrupt mode allow RS232 send/ receive data more than 16 bytes, why I can not do it, I set the sendbuffer to 18 bytes, but still just 16bytes sent out.
Any other setting?
Best Regards,
Roy from UK
Historian
Historian
Re: issues with rs232 interrupt mode
zrh0913 wrote:
Hi, all,
Any other setting?
Best Regards,
Roy from UK
Not knowing anything else about your design, it's possible that your UART core has a 16-byte outgoing-data FIFO. You must ensure that you don't try to write to a full FIFO.
Visitor cems
RS232 protocol (UART) works on multiples of 8 bits i think. Try to change the number of data bits property of the RS232 IP. If 6 data bits is allowed your problem can be solved.
Take care.
Historian
Historian
zrh0913 wrote:
Hi, all,
Any other setting?
Best Regards,
Roy from UK
Historian
Historian
Take care.
Huh? This is ridiculous.
Observer zrh0913
Thank you for your reply, It because the Uart FIFO is 16 Bytes. But to send 16 Bytes in 1ms seems a bit difficult based on my test. The communication is between MATLAB/SIMULINK and FPGA, probably, the data transsmision slow is caused by my simulink RS232 blocks.
Now, i changed to use UDP,  I need to send 40 Bytes data in 1 ms, hope UDP can help me achieve that.
