java.lang.NullPointerException --- com.xilinx.sdk.appwiz.core.LinuxProjectHandler.getDirectory(LinuxProjectHandler.java:379)
I  trying to a use petalinux on utuntu
I have successively built a peta linux project , but have to the install deprecated ia32-libs
to solve a petalinux-build problem.
I check all the dependences and installed them for the SDK 2014.4
And referenced root file system and petalinx tool chain  as per  the  following image
But every time I finish or include Hello.c and then finish get the following expection
        at com.xilinx.sdk.appwiz.core.LinuxProjectHandler.getDirectory(LinuxProjectHandler.java:379)
        at com.xilinx.sdk.appwiz.core.LinuxProjectHandler.getArmLinuxIncluedePath(LinuxProjectHandler.java:512)
Can anybody help???
