lbstdc++6 not found
When I launch SDK (Ubuntu 16.04, Vivado 2016.4), I get this:
Launching SDK with command /home/daryl/Xilinx/SDK/2016.4/eclipse/lnx64.o/eclipse -data /home/daryl/Dropbox/zynqbook/Zedboard/zynq_interrupts/zynq_interrupts.sdk -vmargs -Dcom.xilinx.sdk.args.hwspec=/home/daryl/Dropbox/zynqbook/Zedboard/zynq_interrupts/zynq_interrupts.sdk/zynq_interrupt_system_wrapper.hdf -Xms64m -Xmx512m -Dorg.eclipse.swt.internal.gtk.cairoGraphics=false
/home/daryl/Xilinx/SDK/2016.4/lib/lnx64.o/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/lib/x86_64-linux-gnu/libproxy.so.1)
Failed to load module: /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
When I run "locate libstdc++.so.6", I find 62 copies, not including all the *gdb.py ones, and most of those are in Xilinx directories.
What's the recommended fix for that?  FWIW, SDK seems to run just fine without it.
Re: lbstdc++6 not found
Hi @daryllee
I think that your issue is already solved in the following post.
Basically I would say that the libproxy library within your OS requires a newer GLIBC version than the one included within the SDK installation directory. So the solution is just remove (or rename) the built-in library within the SDK and link the library within your OS which is sync with libproxy version.
https://askubuntu.com/questions/699440/version-glibcxx-3-4-20-not-found
Ibai
Hi @daryllee,
You may want to have a look to AR#66184
Let me know if that helps,
Florent
Florent
Hi @daryllee
Ibai
cd /opt/Xilinx/Vivado/2017.4/ids_lite/ISE/lib/lin64
mv libstdc++.so.6 libstdc++.so.6.0.8
sudo ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21 libstdc++.so.6
