-lrsa cannot found while creating FSBL Application in SDK 14.7
Hi All,
           I am trying to create fsbl for zynq AMP in sdk 14.7 but facing the problem which is given below.
c:/xilinx/14.7/ise_ds/edk/gnu/arm/nt/bin/../lib/gcc/arm-xilinx-eabi/4.7.3/../../../../arm-xilinx-eabi/bin/ld.exe: cannot find -lrsa
collect2.exe: error: ld returned 1 exit status
make: *** [amp_fsbl.elf] Error 1
I searched previous answer records and i found the same problem query for sdk14.5. And then i followed the answer steps but still i coulnt able to solve the issue. Please help me to solve this problem.
i tried with following links which is given below
http://www.xilinx.com/support/answers/55581.html
Ramesh
Re: -lrsa cannot found while creating FSBL Application in SDK 14.7
@ramesh.d2015
A similar issue is discussed in the thread http://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-ld-exe-cannot-find-lrsa/td-p/330545
Refer to the "ljump@drs.com"post which might fix the issue for you.
Please update us on the fix so that we can try updating the solution.
Achutha
Hi Achutha,
                     I refered that post already  which you have given now,
In that post,
Xilinx has updated the design files:
http://www.wiki.xilinx.com/XAPP1078+Latest+Information
http://www.wiki.xilinx.com/XAPP1079+Latest+Information
these links contains the design files of EDK & SDK versions 14.5 and 14.6, but i am using 14.7.
With these design files i am trying to create the fsbl for zynq AMP in 14.7 version but i am getting error.
Also they discussed the solution from this link http://www.xilinx.com/support/answers/55581.htm. I tried with this also but it not working for me.
Ramesh
hi,
RSA support was only added in 14.5.check if your FSBL is based off Standalone BSP v3.7
To create a FSBL without error, you can remove the rsa option in C/C++ propoerties and change BSP version to the latest.
--hem
Hi Hem,
              Actually i have the design files of AMP example design on zynq zc702. It contains fsbl,boot.bin etc and directly i implemented it on board and its working properly. But i wanted to create all the files from the scratch, i have created u-bbot.elf,kernel,filesystem ( they explained in the doc how do these things). And then while creating fsbl i am facing this issue and i reffered all the links and answer records but i couldn't solve it. Also i tried with what you explained.
If i remove or add the -lrsa from C/C++ settings also i am getting the same error and i do not know how they created the BSP for this example design but still i tried that also. Now i do not know what to do and how to solve this problem.
the ref design files are in this link,
Ramesh
