lunch hardware server in Vivado 2013.3
Hi everyone,
I am using Vivado 2013.3 and when I export hardware to SDK, I should start SDK hardware server but I do not know how to do that in Linux. because I can find hw_server but when I enter ./hw_server I got this error
./hw_server: error while loading shared libraries: libxftdi.so: cannot open shared object file: No such file or directory
what should I do ?
thanks,
Meysam
Re: lunch hardware server in Vivado 2013.3
the answer is mentioned in
http://stackoverflow.com/questions/480764/linux-error-while-loading-shared-libraries-cannot-open-shared-object-file-no-s
so accordingly, I did
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/path of object file/libxftdi.so
export LD_LIBRARY_PATH
and it works to me
regards,
Meysam
Thanks for posting the solution. Please mark your post as solution to help other forum members.
Thanks,Vijay
Can you try the following steps:
1. Open your SDK workspace
2. Xilinx Tools > Launch Shell ...
3. In the bash, type the command "hw_server" (without quotes)
This should start the hardware server. If not, please post the screenshot of the output.
BTW, which OS are you using?
but when I cloick on launch shell nothing happened I have that cosole but noit able to type anything in there
thanks
Meysam
when I hit the launch shell I got
4:52:11 ERROR : Unexpected Exception while launch bash shell: {} java.io.IOException: Cannot run program "xterm" (in directory "/home/meysam/Xilinx_project/Microblaze_MIG/Microblaze_MIG.sdk/SDK/SDK_Export"): java.io.IOException: error=2, No such file or directory
at java.lang.ProcessBuilder.start(Unknown Source)
at com.xilinx.sdk.xbash.OpenXBashHandler$1.run(Unknown Source)
can you help me out of this
meysam
