lwIP in SDK
Hi, Im trying to compile in SDK this simple test code: (It shouldn't works, only compiles)
#include "xparameters.h"
#include "xmk.h"
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <os_config.h>
#define LWIP_TIMEVAL_PRIVATE 0
#include "lwip/sockets.h"
#include "lwipopts.h"
#include "netif/xadapter.h"
#include <pthread.h>
#include "lwip/inet.h"
static struct tcp_pcb *connected_pcb = NULL;
int main()
    struct netif *netif;
    struct netif server_netif;
    lwip_init();
    sys_thread_new("thread", (void*)xemacif_input_thread, netif, 1024, DEFAULT_THREAD_PRIO);
return 0;
And I get error message like this:
make all
powerpc-eabi-gcc -c -mcpu=440 -I../../ppc440_0_sw_platform/ppc440_0/include -g -O0 -omain.o ../main.c
Building target: lwIP_c.elf
powerpc-eabi-gcc -o lwIP_c.elf main.o    -mcpu=440  -L../../ppc440_0_sw_platform/ppc440_0/lib   -T../lwIP_c.ld -llwip4 -l xilkernel
../../ppc440_0_sw_platform/ppc440_0/lib/liblwip4.a(xadapter.o): In function `xemacif_input_thread':
/cygdrive/d/FPGA_Projects/xv5_pci_edk/SDK_projects/ppc440_0_sw_platform/ppc440_0/libsrc/lwip130_v1_00_a/src/contrib/ports/xilinx/netif/xadapter.c:154: undefined reference to `yield'
../../ppc440_0_sw_platform/ppc440_0/lib/liblwip4.a(xlltemacif_fifo.o): In function `init_ll_fifo':
/cygdrive/d/FPGA_Projects/xv5_pci_edk/SDK_projects/ppc440_0_sw_platform/ppc440_0/libsrc/lwip130_v1_00_a/src/contrib/ports/xilinx/netif/xlltemacif_fifo.c:191: undefined reference to `register_int_handler'
/cygdrive/d/FPGA_Projects/xv5_pci_edk/SDK_projects/ppc440_0_sw_platform/ppc440_0/libsrc/lwip130_v1_00_a/src/contrib/ports/xilinx/netif/xlltemacif_fifo.c:194: undefined reference to `enable_interrupt'
/cygdrive/d/FPGA_Projects/xv5_pci_edk/SDK_projects/ppc440_0_sw_platform/ppc440_0/libsrc/lwip130_v1_00_a/src/contrib/ports/xilinx/netif/xlltemacif_fifo.c:197: undefined reference to `register_int_handler'
/cygdrive/d/FPGA_Projects/xv5_pci_edk/SDK_projects/ppc440_0_sw_platform/ppc440_0/libsrc/lwip130_v1_00_a/src/contrib/ports/xilinx/netif/xlltemacif_fifo.c:200: undefined reference to `enable_interrupt'
../../ppc440_0_sw_platform/ppc440_0/lib/liblwip4.a(xlltemacif_sdma.o): In function `init_sdma':
/cygdrive/d/FPGA_Projects/xv5_pci_edk/SDK_projects/ppc440_0_sw_platform/ppc440_0/libsrc/lwip130_v1_00_a/src/contrib/ports/xilinx/netif/xlltemacif_sdma.c:743: undefined reference to `register_int_handler'
/cygdrive/d/FPGA_Projects/xv5_pci_edk/SDK_projects/ppc440_0_sw_platform/ppc440_0/libsrc/lwip130_v1_00_a/src/contrib/ports/xilinx/netif/xlltemacif_sdma.c:757: undefined reference to `enable_interrupt'
collect2: ld returned 1 exit status
make: *** [lwIP_c.elf] Error 1
Build complete for project lwIP_c
It happens only when I use  'xemacif_input_thread' ...(of course, I need this to server app)
I configured lwIP 1.3 , xilkernel etc...
I'm using lltemac and LocalLink fifo in my hardware project.
and I don't know what now..
(SDK/EDK 10.1 , PPC440 , ML507)
thanks for replies!
It looks like you haven't configured xilkernel completely. For instance, the yield functionality in xilkernel is available only if you have enhanced_features/config_yield enabled in your MSS. Try comparing the xilkernel section of your MSS with the MSS file in the appnote.
You're right, I had to set sysintc_spec and enhanced_features, thanks a lot.
