aod62
lwip - RAW - two connections collide
I am using the "standalone" program and lwip in "RAW" mode.  I have a problem when two connections connect requesting a file at the same-ish time.  The file is 16MByte so I am using  the sent_callback() function to send the file in blocks when there is some space in tcp_sndbuf().  If one connection has downloaded say 1/2 the file and another connection requests the same file.  The system gets it's knickers in a twist and you have to request the file from one connection several times to get it to download properly.
Any ideas?
I have included the sent_callback() function below in case I am doing something silly
err_t sent_callback(struct http_arg *arg, struct tcp_pcb *tpcb, struct pbuf *p, u16_t len)
    int num, bytesleft;
//    Xuint8 *rambuf = (Xuint8*)MFS_IMAGE_BASEADDR;
    /* if connection is closed, or there is no data to send */
    if (tpcb->state > ESTABLISHED) {
    return ERR_OK;
    if(arg->fsize)
        num = tcp_sndbuf(tpcb);
        bytesleft = arg->fsize;
        if(num > (TCP_SND_BUF/2) || num >= bytesleft)   //set to 1/2 the send buffer length
            if(num > bytesleft)
                //rambuf = (Xuint32)MFS_IMAGE_BASEADDR + (Xuint32)(DATA_FILESIZE-bytesleft);
                tcp_write(tpcb, (Xuint32*)arg->buff, bytesleft, 1);
                arg->fsize = 0;
                pbuf_free(p);
                //tcp_close(tpcb);
            }else{
                tcp_write(tpcb, (Xuint32*)arg->buff, num, 1);
                arg->fsize -= num;
                arg->buff += num;
                //xil_printf("%d - %d,",num,arg->fsize);
    }else
        //tcp_close(tpcb);
    return ERR_OK;
