Visitor fft442
lwip_write() block issue
I used the sample program of XAPP1026 to run at PowerPC440 of V5FX100T, with lwip140_v1_0_a in ISE14.7.
And I called lwip_write() in while to send data endlessly. The program will block after about 20 minutes.
Same program run well in ISE13.1.  Can anyone give me some hints? Thanks!
Following is the key code. Complete code can be found in attached file.
    while(lwip_connect(sock, (struct sockaddr *)&serv_addr, sizeof (serv_addr)) < 0)
        xil_printf("Can not connect to server.\n\r");
        lwip_close(sock);
        if ((sock = lwip_socket(AF_INET, SOCK_STREAM, 0)) < 0) {
            xil_printf("error creating socket\n\r");
            return;
        sleep(1000);
    print("Connected\n\r");
    while (lwip_write(sock, send_buf, SEND_BUFSIZE) >= 0) {
//        for(i = 0; i < 0xffff; i++);
    print("TX perf stopped\n\r");
Visitor fft442
Re: lwip_write() block issue
After every block of Lwip_write, there is always an ARP request and respond. But after that, the lwip still blocked. See attached wireshark captured result.
Visitor fft442
When set LWIP_STATS=true, I got following messege:
MEM TCPIP_MSG_INPKT
       avail: 8
       used: 8
       max: 8
       err: a00
It seemed that lwip memory has some error, and the arp information is lost.
Anyone met the same problem in ISE14.7 with lwip1.4.0?
I know this is quite old, but I am seeing TCPIP_MSG_INPKT errors.  I changed the MEMP_NUM_TCPIP_MSG_INPKT value to a larger value, and am testing now.  Did you resolve this issue?
#define MEMP_NUM_TCPIP_MSG_INPKT 128
