geetha.diwakar
map file in sdk
hello,
where can i find map file in sdk?tell me the path?
thank you
maps-mpls
Mentor
Mentor
SDK does not create a map file be default as far as I can tell.
To get it to generate a map file, go to build settings-> ARM v7 gcc linker -> inferred options -> software platform
Add the following flag with the green + (with whatever path/filename you want):
-Wl,-M=c:/delme/test.map
Or if you're asking about microblaze, see here or UG1043.
*** Destination: Rapid design and development cycles *** Unappreciated answers get deleted, unappreciative OPs get put on ignored list ***
