niu_mao_ning
mem_wait pin issue in EMC
Hi Geeks,
I wish to post a issue I faced while building system with emc to connect numonyx flash device in my design.
In emc configuration when I am choosing numonyx flash device it will generate mem_wait signal which is a handshaking signal for the proper communication between numonyx flash and the processor.
I made mem_wait signal and other emc signals such as mem_wen,mem_ren,mem_cen,mem_ben etc., All pins are well assigned when i am building. (for your information there is no error in ucf. I verified it) except mem_wait signal and it displays an warning as follows:
WARNING:MapLib:701 - Signal axi_emc_0_Mem_WAIT_pin connected to top level port
   axi_emc_0_Mem_WAIT_pin has been removed.
since it is removed I am not able to send my  handshaking signals through mem_wait.
Kindly let me know the issue Why it is removed automatically removed from device?
And how to resolve it?
I am eagerly waiting for your ideas and suggestions.
Every suggestions is greatly appreciated. Thanks in advance.
htsvn
This issue was reported and is fixed in 14.2 ISE. Can you please try this in a later version than ISE 14.2?
--Hem
niu_mao_ning
Thanks for the response Hem,
Sorry I forget to mention the version I used. Actually I am using Xilinx 14.6 version. Still I am facing the issue of that removal of mem_wait pin from my design. Can you give any suggestion for this?
Thanks in advance !
htsvn
Can you attach your XMP,MHS and the UCF of your design?
--Hem
niu_mao_ning
Yeah, Sure Hem
Here with I have attached xmp , UCF and mhs file for your reference. These files are for xilinx 14.5 version. For your information I tried it in 14.4,14.6 and 14.7 also.
Kindly go through it and help me to sort out the issues.
Thank you.
htsvn
To make hte wait pin prevent from being optimized, please use this parameter in your MHS.
PARAMETER C_LINEAR_FLASH_SYNC_BURST = 1
This seems to work at my end.
--Hem
niu_mao_ning
Hi Hem,
Thanks for your valuable hint. let me check and come up with results....
niu_mao_ning
Hi Hem
I wish to have one clarification,
This parameter is for burst mode transfer of data(PARAMETER C_LINEAR_FLASH_SYNC_BURST = 1). If I am correct
should we set this parameter for normal data transmission (that is i mean byte by byte or 16 bit transmission of data)...?
Kindly clarify me,
htsvn
There was a CR filed based on this issue that you were seeing. The number for it is 771045
--Hem
