mfsgen adds empty files since SDK 2014.1
Command:
 /opt/Xilinx/SDK/2014.2/bin/mfsgen -vbcf filesystemn.mfs 50 TXTAB_16.BIN
Output:
****** xilmfs
****** SDK v2014.2 (64-bit)
  **** SW Build 932637 on Wed Jun 11 13:12:06 MDT 2014
    ** Copyright 1986-2014 Xilinx, Inc. All Rights Reserved.
TXTAB_16.BIN  0
MFS block usage (used / free / total) = 2 / 48 / 50
Size of memory is 26600 bytes
Block size is 532
mfsgen done!
mfsgen sees and adds the file TXTAB_16.BIN as if it has a size of 0 which isn't the case:
ls -al TXTAB_16.BIN
-rw-rw-r--. 1 me me 14400  2. Jun 11:22 TXTAB_16.BIN
This worked OK with SDK 2013.4 but fails with SDK 2014.1 and 2014.2.
System: centos 6.5 x86_64
Any suggestions?
Could someone please try this and report the results?
Any "works for me on RHEL/Centos 6"  or  "Fails here, too" would help to decide how to proceed.
Fails on Ubuntu 14.04LTS + SDK 2014.2
mfsgen -vbcf ../image.mfs 2048 index.html index2.html image.png
****** xilmfs
index.html 0
index2.html 0
image.png 0
MFS block usage (used / free / total) = 4 / 2044 / 2048
Size of memory is 1089536 bytes
Block size is 532
mfsgen done!
hi,
this issue is under investigation and will be fixed in the future release of software.
--hem
