Anonymous
Not applicable
mfsgen : files extraction from .mfs file
Hi to all.
How can I extract the files from an .mfs file on Windows/Linux machine?
If I use mfsgen -x "c:\filesystem.mfs" command I cannot see the files list, see below:
C:\Xilinx\SDK\2016.4\bin>mfsgen -x c:\filesystem.mfs
****** xilmfs
****** SDK v2016.4 (64-bit)
  **** SW Build 1733598 on Wed Dec 14 22:35:39 MST 2016
    ** Copyright 1986-2016 Xilinx, Inc. All Rights Reserved.
mfsgen done!
Mauro
shabbirk
Hi Mauro
Try something like this on Linux:-
Extract the file in a different area:
      		mkdir tmp; cd tmp; cp ../tmp.mfs .; ../mfsgen -xvf tmp.mfs
Best Regards
Shabbir
