Observer stevekuznicki
microblaze application build FAILS - help!
It seems like in my project the microblaze directory gets created read-only, then XPS attempts to copies files to it.
Has anyone else ran into this problem and how to remedy it?  Why would XPS create the dir read-only then attempt to copy files to it!!??
Building Directory Structure for microblaze_0
Generating platform libraries and device drivers ...
Running CopyFiles ...
Copying files for os standalone_v1_00_a from
C:\Xilinx\10.1\EDK\sw\lib\bsp\standalone_v1_00_a\src\ to
C:\work\spartan3a\Impulse_AVK_FishFinder_Lab\Project_1_Passthrough_Completed\mic
roblaze_0\libsrc\standalone_v1_00_a\ ...
INTERNAL_ERROR:MDT:MdtBas_Common.c:939:1.80.6.40 - Can not create valid UT_DIR
   object in MakeWriteable
ERROR:MDT - Failed to add write permission for
   microblaze_0\libsrc\standalone_v1_00_a\
ERROR:MDT - Failed to copy C:\Xilinx\10.1\EDK\sw\lib\bsp\standalone_v1_00_a\src\
   to
etc... there is a lot of errors of the same
thanks
Steve
Re: microblaze application build FAILS - help!
Solution:  (from Xilinx AR #25492 -10.1 EDK)
This issue occurs with some IBM PCs. To work around this issue, add the Environment Variable CYGWIN=nontsec as follows:
1. Right-click the My Computer icon and select Properties.
2. Select the Advanced tab.
3. Select the Environment Variables button.
4. Under System variables, select the New button.
5. For the variable name, enter CYGWIN.
6. For the variable value, enter "nontsec".
7. Select the OK button three times.
8. If XPS was open, restart XPS so that it will recognize the new environment variable.
~stevek
Tags (4)
~stevek
Tags (4)
