mpmc initdone problem
I am using mpmc 4.02 in edk 10.1.02 platform.  At startup in the C code, I am waiting mpmc to initialize(initdone) itself, but it does not.Then i reset only mpmc and initdone works, but the other port which is connected to ISE platform crashes. The first data sets are not written properly when i try to write data from this port.  After 32 byte data, write operation works well.  At each trial, the first data sets are not written properly. What can i do?
Aziz
Re: mpmc initdone problem
what memory are you interfacing too?  What does the MHS look like?
Hi dcherry,
Can you please help me with my InitDone problem? Many thanks.
http://forums.xilinx.com/t5/Embedded-Processing/sos-Problem-with-MPMC-Clk0-InitDone-remains-LOW/td-p/228505
