04-29-2008 04:46 AM
Using XPS 10.1sp1, having selected "Hardware=>Generate Bitstream", the XPS IDE locks-up with the following message:
"FATAL_ERROR:GuiUtilities:Gq_Application.c:590:1.20..." in a Dialog box and XPS no longer responds, the error is intermittant, sometimes
ngdbuild runs to completion without incident. Has anyone else seen this error?
05-19-2008 03:45 AM
I also suffer from this but I have found the following at least reduces it
1. copy the EDK make file (i.e "yourprojname".make) giving it a new name (keep it in the same dir)
2. edit the make file copy and change the lines
@xflow -wd implementation -p $(DEVICE) -implement xflow.opt $(SYSTEM).ngc
and
@cd implementation; bitgen -w -f bitgen.ut $(SYSTEM)
to
@xflow -wd implementation -p $(DEVICE) -implement xflow.opt $(SYSTEM).ngc >> $(SYSTEM)_build.log
@cd implementation; bitgen -w -f bitgen.ut $(SYSTEM) >> $(SYSTEM)_build.log
after the lines
@echo "*********************************************"
@echo "Running Xilinx Implementation tools.."
@cp -f $(UCF_FILE) implementation/$(SYSTEM).ucf
add
@rm -f $(SYSTEM)_build.log
3. In the EDK GUI under Project/project options set the edited make as the custom make file to use.
The effect of this is to redirect the log output from the build to a file and not into the EDK gui transcript window. The dissadvantage
is you now can't see the build progress (open the log file "$(SYSTEM)_build.log" in a "good" editior to follow it) and if
you do changes to the proj i.e. add a new Proj software app the make file will be out of date (i.e. you have to do the above again using the EDK generated make file, I supose it is possible to write a make the edits the EDK generated make etc... but thats a lot of work)
Overall its better then having the build crash 2 hours into the build and having to re-do/re_do.....
I also seen the fatal crash during sim gen so the method may also work on the make files sim gen sections but I've not tried that.
04-29-2008 11:25 AM
Yes I have. Frequently. Whenever I get that error, I:
1) Shutdown the SDK (if it is open) and EDK.
2) Reboot the computer.
3) Cross my fingers and try again.
More often than not, the Bitstream builds properly the second time around. It has been known to take up to three attempts though. With each build taking about 1.5 hours each it can make for a VERY...boring.....day.
04-29-2008 11:27 AM
05-19-2008 03:45 AM
and
to
after the lines
add
05-19-2008 06:21 AM
